<< Click to Display Table of Contents >> VerticalPercentFill |
Use this property to specify a percentage of an object's vertical area to fill. Acceptable values for this property vary from 0 (zero) to 100. This property works along with the VerticalFillStyle property, which indicates how this fill occurs. Default value of this property is 100.
