BorderColor |
Specifies a color for an object's border or line. This property is only used when the BorderStyle property is not configured to 5 (five, Null), where an object does not have a border. In scripts, use VBScript's RGB method to create a color to link to this property. Default value of this property is white (RGB(255, 255, 255)), except for Display and SetPoint objects, whose default value is dark gray (RGB(128,128,128)).
