<< Click to Display Table of Contents >> ShadowY |
Defines the upper horizontal coordinate of an object's shadow, in Himetric units. This shadow is always relative to the object's Y property. Positive values indicate that this shadow is below an object, and negative ones above. Default value of this property is 200.
