<< Click to Display Table of Contents >> BackgroundStyle |
This property specifies a fill mode for an object's background. This property enables using the VerticalPercentFill and HorizontalPercentFill properties with values different from 100, and also set the FillStyle property with values between 2 (two) and 8 (eight). This forces the remaining area to use a background color configured in the BackgroundColor property for filling. The following table contains valid values for this property.
Available options for the BackgroundStyle property
Option |
Description |
0 - Transparent |
No background is drawn |
1 - Opaque |
If visible, a background is drawn (default) |
