ForegroundColor |
This property specifies a color for an object's foreground. This color is used when the FillStyle property is set to 0 (zero, solid) or between 2 (two) and 9 (nine). In scripts, use VBScript's RGB method to create a color to link to this property. Default value of this property is blue (RGB(0, 0, 255)), except for Display and SetPoint objects, whose default value is white (RGB(255, 255, 255)).
