eventEnrollment.faultParameters
Determines the fault algorithm used to monitor the referenced object and provides the parameter values needed for this fault algorithm. If the Event Enrollment object does not apply a fault algorithm, then the fault parameter choice NONE shall be set in this property.
Property faultParameters of object eventEnrollment can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
eventEnrollment-<objectAddress>.faultParameters
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 9
N3:
<objectAddress>
N4:
<property> = 358
Tag Value
•A null/empty value.
•A character string containing an XML with a value of type <BACnetFaultParameter_FaultCharacterstring>.
•A character string containing an XML with a value of type <BACnetFaultParameter_FaultExtended>.
•A character string containing an XML with a value of type <BACnetFaultParameter_FaultLifeSafety>.
•A character string containing an XML with a value of type <BACnetFaultParameter_FaultState>.
•A character string containing an XML with a value of type <BACnetFaultParameter_FaultStatusFlags>.
•A character string containing an XML with a value of type <BACnetFaultParameter_FaultOutOfRange>.
•A character string containing an XML with a value of type <BACnetFaultParameter_FaultListed>.
