BACnetFaultParameter_FaultStatusFlags
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.faultParameters
XML Schema
  <xs:complexType name="BACnetFaultParameter_FaultStatusFlags">
    <xs:sequence>
      <xs:element name="StatusFlagsReference" type="BACnetDeviceObjectPropertyReference" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetFaultParameter_FaultStatusFlags" />
</xs:schema>
Examples
Example 1:
  <BACnetFaultParameter_FaultStatusFlags>
    <StatusFlagsReference>
      <ObjectIdentifier>device-501</ObjectIdentifier>
      <PropertyIdentifier>ackRequired</PropertyIdentifier>
      <PropertyArrayIndex>1236</PropertyArrayIndex>
      <DeviceIdentifier>device-504</DeviceIdentifier>
    </StatusFlagsReference>
  </BACnetFaultParameter_FaultStatusFlags>
</Value>
