BACnetFaultParameter_FaultExtended
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.faultParameters
XML Schema
  <xs:complexType name="BACnetFaultParameter_FaultExtended">
    <xs:sequence>
      <xs:element name="VendorId" type="Unsigned16" />
      <xs:element name="ExtendedFaultType" type="Unsigned" />
      <xs:element name="Parameters" type="SequenceOfBACnetFaultParameter_FaultExtended_Unnamed" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetFaultParameter_FaultExtended" />
</xs:schema>
Examples
Example 1:
  <BACnetFaultParameter_FaultExtended>
    <VendorId>7634</VendorId>
    <ExtendedFaultType>1235</ExtendedFaultType>
    <Parameters />
  </BACnetFaultParameter_FaultExtended>
</Value>
Example 2:
    <VendorId>7636</VendorId>
    <ExtendedFaultType>1237</ExtendedFaultType>
    <Parameters>
      <Unnamed>
        <Null />
      </Unnamed>
      <Unnamed>
        <Null />
      </Unnamed>
      <Unnamed>
        <Null />
      </Unnamed>
    </Parameters>
</Value>
