BACnetFaultParameter_FaultLifeSafety
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.faultParameters
XML Schema
  <xs:complexType name="BACnetFaultParameter_FaultLifeSafety">
    <xs:sequence>
      <xs:element name="ListOfFaultValues" type="SequenceOfBACnetLifeSafetyState" />
      <xs:element name="ModePropertyReference" type="BACnetDeviceObjectPropertyReference" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetFaultParameter_FaultLifeSafety" />
</xs:schema>
Examples
Example 1:
  <BACnetFaultParameter_FaultLifeSafety>
    <ListOfFaultValues />
    <ModePropertyReference>
      <ObjectIdentifier>device-501</ObjectIdentifier>
      <PropertyIdentifier>ackRequired</PropertyIdentifier>
      <PropertyArrayIndex>1236</PropertyArrayIndex>
      <DeviceIdentifier>device-504</DeviceIdentifier>
    </ModePropertyReference>
  </BACnetFaultParameter_FaultLifeSafety>
</Value>
Example 2:
    <ListOfFaultValues>
      <BACnetLifeSafetyState>faultPreAlarm</BACnetLifeSafetyState>
      <BACnetLifeSafetyState>faultAlarm</BACnetLifeSafetyState>
      <BACnetLifeSafetyState>notReady</BACnetLifeSafetyState>
    </ListOfFaultValues>
      <ObjectIdentifier>device-508</ObjectIdentifier>
      <PropertyIdentifier>all</PropertyIdentifier>
      <PropertyArrayIndex>1243</PropertyArrayIndex>
      <DeviceIdentifier>device-511</DeviceIdentifier>
</Value>
