SequenceOfBACnetLifeSafetyState
This XML representation of complex data is used by the following objects/properties:
•lifeSafetyPoint.alarmValues
•lifeSafetyPoint.faultValues
•lifeSafetyPoint.lifeSafetyAlarmValues
•lifeSafetyZone.alarmValues
•lifeSafetyZone.faultValues
•lifeSafetyZone.lifeSafetyAlarmValues
XML Schema
  <xs:complexType name="SequenceOfBACnetLifeSafetyState">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetLifeSafetyState" type="BACnetLifeSafetyState" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetLifeSafetyState" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetLifeSafetyState />
</Value>
Example 2:
  <SequenceOfBACnetLifeSafetyState>
    <BACnetLifeSafetyState>quiet</BACnetLifeSafetyState>
    <BACnetLifeSafetyState>preAlarm</BACnetLifeSafetyState>
    <BACnetLifeSafetyState>alarm</BACnetLifeSafetyState>
  </SequenceOfBACnetLifeSafetyState>
</Value>
