BACnetLifeSafetyState |
<xs:simpleType name="BACnetLifeSafetyState">
<xs:enumeration value="quiet" />
<xs:enumeration value="preAlarm" />
<xs:enumeration value="alarm" />
<xs:enumeration value="fault" />
<xs:enumeration value="faultPreAlarm" />
<xs:enumeration value="faultAlarm" />
<xs:enumeration value="notReady" />
<xs:enumeration value="active" />
<xs:enumeration value="tamper" />
<xs:enumeration value="testAlarm" />
<xs:enumeration value="testActive" />
<xs:enumeration value="testFault" />
<xs:enumeration value="testFaultAlarm" />
<xs:enumeration value="holdup" />
<xs:enumeration value="duress" />
<xs:enumeration value="tamperAlarm" />
<xs:enumeration value="abnormal" />
<xs:enumeration value="emergencyPower" />
<xs:enumeration value="delayed" />
<xs:enumeration value="blocked" />
<xs:enumeration value="localAlarm" />
<xs:enumeration value="generalAlarm" />
<xs:enumeration value="supervisory" />
<xs:enumeration value="testSupervisory" />
</xs:restriction>
</xs:simpleType>
Example 1:
<BACnetLifeSafetyState>quiet</BACnetLifeSafetyState>
