lifeSafetyPoint.alarmValues |
Specifies any states the presentValue must equal before a TO-OFFNORMAL event is generated.
Property alarmValues of object lifeSafetyPoint can be read and written using a single IOTag.
lifeSafetyPoint-<objectAddress>.alarmValues |
<type> = 21 |
<property> = 7 |
A character string containing an XML with a value of type <SequenceOfBACnetLifeSafetyState>.
