BACnetFaultParameter_FaultListed |
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.faultParameters
<xs:complexType name="BACnetFaultParameter_FaultListed">
<xs:sequence>
<xs:element name="FaultListReference" type="BACnetDeviceObjectPropertyReference" />
</xs:sequence>
</xs:complexType>
<xs:element name="Value" type="BACnetFaultParameter_FaultListed" />
</xs:schema>
Example 1:
<BACnetFaultParameter_FaultListed>
<FaultListReference>
<ObjectIdentifier>device-501</ObjectIdentifier>
<PropertyIdentifier>ackRequired</PropertyIdentifier>
<PropertyArrayIndex>1236</PropertyArrayIndex>
<DeviceIdentifier>device-504</DeviceIdentifier>
</FaultListReference>
</BACnetFaultParameter_FaultListed>
</Value>
