BACnetFaultParameter_FaultOutOfRange
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.faultParameters
XML Schema
  <xs:complexType name="BACnetFaultParameter_FaultOutOfRange">
    <xs:sequence>
      <xs:element name="MinNormalValue" type="BACnetFaultParameter_FaultOutOfRange_MinNormalValue" />
      <xs:element name="MaxNormalValue" type="BACnetFaultParameter_FaultOutOfRange_MaxNormalValue" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetFaultParameter_FaultOutOfRange" />
</xs:schema>
Examples
Example 1:
  <BACnetFaultParameter_FaultOutOfRange>
    <MinNormalValue>
      <Real>1234.567749</Real>
    </MinNormalValue>
    <MaxNormalValue>
      <Real>1235.567749</Real>
    </MaxNormalValue>
  </BACnetFaultParameter_FaultOutOfRange>
</Value>
