BACnetFaultParameter_FaultOutOfRange_MinNormalValue |
<xs:complexType name="BACnetFaultParameter_FaultOutOfRange_MinNormalValue">
<xs:sequence>
<xs:choice>
<xs:element name="Real" type="REAL" />
<xs:element name="Unsigned" type="Unsigned" />
<xs:element name="Double" type="Double" />
<xs:element name="Integer" type="INTEGER" />
</xs:choice>
</xs:sequence>
</xs:complexType>
Example 1:
<BACnetFaultParameter_FaultOutOfRange_MinNormalValue>
<Real>1234.567749</Real>
</BACnetFaultParameter_FaultOutOfRange_MinNormalValue>
Example 2:
<Unsigned>1235</Unsigned>
Example 3:
<Double>123458.789012</Double>
Example 4:
<Integer>-797</Integer>
