BACnetFaultParameter_FaultState
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.faultParameters
XML Schema
  <xs:complexType name="BACnetFaultParameter_FaultState">
    <xs:sequence>
      <xs:element name="ListOfFaultValues" type="SequenceOfBACnetPropertyStates" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetFaultParameter_FaultState" />
</xs:schema>
Examples
Example 1:
  <BACnetFaultParameter_FaultState>
    <ListOfFaultValues />
  </BACnetFaultParameter_FaultState>
</Value>
Example 2:
    <ListOfFaultValues>
      <BACnetPropertyStates>
        <BooleanValue>true</BooleanValue>
      </BACnetPropertyStates>
    </ListOfFaultValues>
</Value>
