SequenceOfBACnetDeviceObjectPropertyReference
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•channel.listOfObjectPropertyReferences
•globalGroup.groupMembers
•schedule.listOfObjectPropertyReferences
•timer.listOfObjectPropertyReferences
•trendLogMultiple.logDeviceObjectProperty
Esquema XML
  <xs:complexType name="SequenceOfBACnetDeviceObjectPropertyReference">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetDeviceObjectPropertyReference" type="BACnetDeviceObjectPropertyReference" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetDeviceObjectPropertyReference" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetDeviceObjectPropertyReference />
</Value>
Exemplo 2:
  <SequenceOfBACnetDeviceObjectPropertyReference>
    <BACnetDeviceObjectPropertyReference>
      <ObjectIdentifier>device-501</ObjectIdentifier>
      <PropertyIdentifier>ackRequired</PropertyIdentifier>
      <PropertyArrayIndex>1236</PropertyArrayIndex>
      <DeviceIdentifier>device-504</DeviceIdentifier>
    </BACnetDeviceObjectPropertyReference>
      <ObjectIdentifier>device-505</ObjectIdentifier>
      <PropertyIdentifier>activeVtSessions</PropertyIdentifier>
      <PropertyArrayIndex>1240</PropertyArrayIndex>
      <DeviceIdentifier>device-508</DeviceIdentifier>
      <ObjectIdentifier>device-509</ObjectIdentifier>
      <PropertyIdentifier>allWritesSuccessful</PropertyIdentifier>
      <PropertyArrayIndex>1244</PropertyArrayIndex>
      <DeviceIdentifier>device-512</DeviceIdentifier>
  </SequenceOfBACnetDeviceObjectPropertyReference>
</Value>
