Objeto notificationForwarder
Defines a standardized object whose properties represent the externally visible characteristics required for the re-distribution of event notifications to zero or more destinations. It differs from a Notification Class in that the Notification Forwarder object is not used for originating event notifications, but rather is used to forward event notifications to a different and potentially larger number of recipients.
Objetos do tipo notificationForwarder possuem as seguintes propriedades:
•description
•localForwardingOnly
•objectIdentifier
•objectName
•objectType
•outOfService
•portFilter
•processIdentifierFilter
•profileLocation
•profileName
•propertyList
•recipientList
•reliability
•reliabilityEvaluationInhibit
•statusFlags
•subscribedRecipients
•tags
