notificationForwarder.subscribedRecipients |
Conveys a list of recipient destinations to which event notifications are sent when events are forwarded by the Notification Forwarder object. These recipient destinations are intended to be temporary, and will expire if not renewed.
A propriedade subscribedRecipients do objeto notificationForwarder pode ser lida e escrita utilizando um tag normal (IOTag).
notificationForwarder-<endereçoDoObjeto>.subscribedRecipients |
<tipo> = 51 |
<propriedade> = 362 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetEventNotificationSubscription>.
