notificationForwarder.localForwardingOnly |
Indicates whether (TRUE) or not (FALSE) the object is limited to forwarding notifications initiated from within the same device. If Local_Forwarding_Only has a value of FALSE, then the Notification Forwarder is capable of forwarding notifications for other devices.
A propriedade localForwardingOnly do objeto notificationForwarder pode ser lida e escrita utilizando um tag normal (IOTag).
notificationForwarder-<endereçoDoObjeto>.localForwardingOnly |
<tipo> = 51 |
<propriedade> = 360 |
