notificationForwarder.processIdentifierFilter |
Used in the selection of event notification service requests that are to be forwarded by the object. When the Process Identifier parameter of a received event notification is the same as the value of the Process_Identifier_Filter property, or if the Process_Identifier_Filter property contains a NULL, then the notification will be accepted for forwarding by the Notification Forwarder object subject to the port, network and broadcast restrictions.
A propriedade processIdentifierFilter do objeto notificationForwarder pode ser lida e escrita utilizando um tag normal (IOTag).
notificationForwarder-<endereçoDoObjeto>.processIdentifierFilter |
<tipo> = 51 |
<propriedade> = 361 |
Um dos seguintes tipos de dados:
•Um inteiro de 32 bits sem sinal.
•Um valor Null/Empty.
