notificationForwarder.portFilter |
Enables or disables the forwarding of event notifications received on a particular network port. When an event notification is received on a port that is marked as disabled by this property, the Notification Forwarder object shall ignore that event notification.
A propriedade portFilter do objeto notificationForwarder pode ser lida e escrita utilizando um tag normal (IOTag).
notificationForwarder-<endereçoDoObjeto>.portFilter |
<tipo> = 51 |
<propriedade> = 363 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetPortPermission>.
