SequenceOfBACnetPortPermission
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•notificationForwarder.portFilter
Esquema XML
  <xs:complexType name="SequenceOfBACnetPortPermission">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetPortPermission" type="BACnetPortPermission" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetPortPermission" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetPortPermission />
</Value>
Exemplo 2:
  <SequenceOfBACnetPortPermission>
    <BACnetPortPermission>
      <PortId>33</PortId>
      <Enabled>true</Enabled>
    </BACnetPortPermission>
      <PortId>34</PortId>
      <PortId>35</PortId>
  </SequenceOfBACnetPortPermission>
</Value>
