Objeto binaryLightingOutput
Defines a standardized object whose properties represent the externally visible characteristics of a binary lighting output and includes dedicated functionality specific to lighting control that would otherwise require explicit programming. This object is binary in nature and can be either in a logical on or off state. The object is commanded by writing to the Present_Value property. This property is commandable and uses a priority array to arbitrate between multiple writers to the binary lighting output.
Objetos do tipo binaryLightingOutput possuem as seguintes propriedades:
•ackedTransitions
•blinkWarnEnable
•commandTimeArray
•currentCommandPriority
•description
•egressActive
•egressTime
•elapsedActiveTime
•eventDetectionEnable
•eventEnable
•eventMessageTexts
•eventMessageTextsConfig
•eventTimeStamps
•feedbackValue
•lastCommandTime
•notificationClass
•notifyType
•objectIdentifier
•objectName
•objectType
•outOfService
•polarity
•power
•presentValue
•priorityArray
•profileLocation
•profileName
•propertyList
•reliability
•reliabilityEvaluationInhibit
•relinquishDefault
•statusFlags
•strikeCount
•tags
•timeOfActiveTimeReset
•timeOfStrikeCountReset
•valueSource
•valueSourceArray
