binaryLightingOutput.elapsedActiveTime |
Represents the accumulated number of seconds that the presentValue property has had the value ACTIVE since the elapsedActiveTime property was most recently set to a zero value.
A propriedade elapsedActiveTime do objeto binaryLightingOutput pode ser lida e escrita utilizando um tag normal (IOTag).
binaryLightingOutput-<endereçoDoObjeto>.elapsedActiveTime |
<tipo> = 55 |
<propriedade> = 33 |
