SequenceOfBACnetDeviceObjectReference
This XML representation of complex data is used by the following objects/properties:
•accessDoor.doorMembers
•accessPoint.accessDoors
•accessUser.credentials
•accessUser.memberOf
•accessUser.members
•accessZone.credentialsInZone
•accessZone.entryPoints
•accessZone.exitPoints
•lifeSafetyPoint.memberOf
•lifeSafetyZone.memberOf
•lifeSafetyZone.zoneMembers
•structuredView.subordinateList
XML Schema
  <xs:complexType name="SequenceOfBACnetDeviceObjectReference">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetDeviceObjectReference" type="BACnetDeviceObjectReference" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetDeviceObjectReference" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetDeviceObjectReference />
</Value>
Example 2:
  <SequenceOfBACnetDeviceObjectReference>
    <BACnetDeviceObjectReference>
      <DeviceIdentifier>device-501</DeviceIdentifier>
      <ObjectIdentifier>device-502</ObjectIdentifier>
    </BACnetDeviceObjectReference>
      <DeviceIdentifier>device-503</DeviceIdentifier>
      <ObjectIdentifier>device-504</ObjectIdentifier>
      <DeviceIdentifier>device-505</DeviceIdentifier>
      <ObjectIdentifier>device-506</ObjectIdentifier>
  </SequenceOfBACnetDeviceObjectReference>
</Value>
