accessZone.credentialsInZone |
Used to list references to those Access Credential objects that represent credentials assumed to be in this zone. This information may be used to verify whether a specific credential is already in the zone for passback detection purposes. If the zone does not support listing credentials, then this list, if present, shall be empty. It is a local matter as to how this list is updated.
Property credentialsInZone of object accessZone can be read and written using a single IOTag.
accessZone-<objectAddress>.credentialsInZone |
<type> = 36 |
<property> = 266 |
A character string containing an XML with a value of type <SequenceOfBACnetDeviceObjectReference>.
