accessPoint.accessDoors |
Specifies the references to those Access Door objects whose Present_Value properties are commanded after successful authorization. If this Access Point object does not command Access Door objects (e.g., muster point), or is used to control access to other resources or functions, or commands other objects, then this array shall be empty.
Property accessDoors of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.accessDoors |
<type> = 33 |
<property> = 246 |
A character string containing an XML with a value of type <SequenceOfBACnetDeviceObjectReference>.
