accessUser.credentials |
References all Access Credential objects that represent those credentials which are owned by this access user. Each object referenced shall be an Access Credential object.
Property credentials of object accessUser can be read and written using a single IOTag.
accessUser-<objectAddress>.credentials |
<type> = 35 |
<property> = 265 |
A character string containing an XML with a value of type <SequenceOfBACnetDeviceObjectReference>.
