BACnetDeviceObjectReference
This XML representation of complex data is used by the following objects/properties:
•accessDoor.valueSource
•accessDoor.valueSourceArray
•analogOutput.valueSource
•analogOutput.valueSourceArray
•analogValue.valueSource
•analogValue.valueSourceArray
•binaryLightingOutput.valueSource
•binaryLightingOutput.valueSourceArray
•binaryOutput.valueSource
•binaryOutput.valueSourceArray
•binaryValue.valueSource
•binaryValue.valueSourceArray
•bitstringValue.valueSource
•bitstringValue.valueSourceArray
•channel.valueSource
•characterstringValue.valueSource
•characterstringValue.valueSourceArray
•command.valueSource
•dateValue.valueSource
•dateValue.valueSourceArray
•datepatternValue.valueSource
•datepatternValue.valueSourceArray
•datetimeValue.valueSource
•datetimeValue.valueSourceArray
•datetimepatternValue.valueSource
•datetimepatternValue.valueSourceArray
•integerValue.valueSource
•integerValue.valueSourceArray
•largeAnalogValue.valueSource
•largeAnalogValue.valueSourceArray
•lifeSafetyPoint.valueSource
•lifeSafetyZone.valueSource
•lightingOutput.valueSource
•lightingOutput.valueSourceArray
•loadControl.valueSource
•multiStateOutput.valueSource
•multiStateOutput.valueSourceArray
•multiStateValue.valueSource
•multiStateValue.valueSourceArray
•octetstringValue.valueSource
•octetstringValue.valueSourceArray
•positiveIntegerValue.valueSource
•positiveIntegerValue.valueSourceArray
•timeValue.valueSource
•timeValue.valueSourceArray
•timepatternValue.valueSource
•timepatternValue.valueSourceArray
XML Schema
  <xs:complexType name="BACnetDeviceObjectReference">
    <xs:sequence>
      <xs:element minOccurs="0" name="DeviceIdentifier" type="BACnetObjectIdentifier" />
      <xs:element name="ObjectIdentifier" type="BACnetObjectIdentifier" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetDeviceObjectReference" />
</xs:schema>
Examples
Example 1:
  <BACnetDeviceObjectReference>
    <DeviceIdentifier>device-501</DeviceIdentifier>
    <ObjectIdentifier>device-502</ObjectIdentifier>
  </BACnetDeviceObjectReference>
</Value>
Example 2:
    <ObjectIdentifier>device-503</ObjectIdentifier>
</Value>
