accessDoor.valueSourceArray
Indicates the source of the last command at each priority.
Property valueSourceArray of object accessDoor can be read and written using a block tag with 16 elements.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
accessDoor-<objectAddress>.valueSourceArray
Size
16 elements
Numeric Parameters
Property
Value
B1:
<deviceAddress>
B2:
<type> = 30
B3:
<objectAddress>
B4:
<property> = 434
Size:
16 elements
Block Elements
Index
Name
Type
0
elm00
•A null/empty value.
•A character string containing an XML with a value of type <BACnetDeviceObjectReference>.
•A character string containing an XML with a value of type <BACnetAddress>.
1
elm01
2
elm02
3
elm03
4
elm04
5
elm05
6
elm06
7
elm07
8
elm08
9
elm09
10
elm10
11
elm11
12
elm12
13
elm13
14
elm14
15
elm15
