BACnetAddress
BACnetAddress
This XML representation of complex data is used by the following objects/properties:
•accessDoor.valueSource
•accessDoor.valueSourceArray
•analogOutput.valueSource
•analogOutput.valueSourceArray
•analogValue.valueSource
•analogValue.valueSourceArray
•binaryLightingOutput.valueSource
•binaryLightingOutput.valueSourceArray
•binaryOutput.valueSource
•binaryOutput.valueSourceArray
•binaryValue.valueSource
•binaryValue.valueSourceArray
•bitstringValue.valueSource
•bitstringValue.valueSourceArray
•channel.valueSource
•characterstringValue.valueSource
•characterstringValue.valueSourceArray
•command.valueSource
•dateValue.valueSource
•dateValue.valueSourceArray
•datepatternValue.valueSource
•datepatternValue.valueSourceArray
•datetimeValue.valueSource
•datetimeValue.valueSourceArray
•datetimepatternValue.valueSource
•datetimepatternValue.valueSourceArray
•integerValue.valueSource
•integerValue.valueSourceArray
•largeAnalogValue.valueSource
•largeAnalogValue.valueSourceArray
•lifeSafetyPoint.valueSource
•lifeSafetyZone.valueSource
•lightingOutput.valueSource
•lightingOutput.valueSourceArray
•loadControl.valueSource
•multiStateOutput.valueSource
•multiStateOutput.valueSourceArray
•multiStateValue.valueSource
•multiStateValue.valueSourceArray
•octetstringValue.valueSource
•octetstringValue.valueSourceArray
•positiveIntegerValue.valueSource
•positiveIntegerValue.valueSourceArray
•timeValue.valueSource
•timeValue.valueSourceArray
•timepatternValue.valueSource
•timepatternValue.valueSourceArray
XML Schema
  <xs:complexType name="BACnetAddress">
    <xs:sequence>
      <xs:element name="NetworkNumber" type="Unsigned16" />
      <xs:element name="MacAddress" type="OctetString" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetAddress" />
</xs:schema>
Examples
Example 1:
  <BACnetAddress>
    <NetworkNumber>7634</NetworkNumber>
    <MacAddress>00010203040506070809</MacAddress>
  </BACnetAddress>
</Value>
