dateValue.valueSource
Indicates the source of the value of the Mode property.
Property valueSource of object dateValue can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
dateValue-<objectAddress>.valueSource
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 42
N3:
<objectAddress>
N4:
<property> = 433
Tag Value
•A null/empty value.
•A character string containing an XML with a value of type <BACnetDeviceObjectReference>.
•A character string containing an XML with a value of type <BACnetAddress>.
