SequenceOfBACnetAccessEvent
This XML representation of complex data is used by the following objects/properties:
•accessPoint.accessAlarmEvents
•accessPoint.accessTransactionEvents
•accessPoint.failedAttemptEvents
XML Schema
  <xs:complexType name="SequenceOfBACnetAccessEvent">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetAccessEvent" type="BACnetAccessEvent" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetAccessEvent" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetAccessEvent />
</Value>
Example 2:
  <SequenceOfBACnetAccessEvent>
    <BACnetAccessEvent>none</BACnetAccessEvent>
    <BACnetAccessEvent>granted</BACnetAccessEvent>
    <BACnetAccessEvent>muster</BACnetAccessEvent>
  </SequenceOfBACnetAccessEvent>
</Value>
