accessPoint.failedAttemptEvents |
Specifies those access events that are counted as a failed access attempt.
Property failedAttemptEvents of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.failedAttemptEvents |
<type> = 33 |
<property> = 272 |
A character string containing an XML with a value of type <SequenceOfBACnetAccessEvent>.
