BACnetAccessEvent |
<xs:simpleType name="BACnetAccessEvent">
<xs:enumeration value="none" />
<xs:enumeration value="granted" />
<xs:enumeration value="muster" />
<xs:enumeration value="passbackDetected" />
<xs:enumeration value="duress" />
<xs:enumeration value="trace" />
<xs:enumeration value="lockoutMaxAttempts" />
<xs:enumeration value="lockoutOther" />
<xs:enumeration value="lockoutRelinquished" />
<xs:enumeration value="lockedByHigherPriority" />
<xs:enumeration value="outOfService" />
<xs:enumeration value="outOfServiceRelinquished" />
<xs:enumeration value="accompanimentBy" />
<xs:enumeration value="authenticationFactorRead" />
<xs:enumeration value="authorizationDelayed" />
<xs:enumeration value="verificationRequired" />
<xs:enumeration value="noEntryAfterGranted" />
<xs:enumeration value="deniedDenyAll" />
<xs:enumeration value="deniedUnknownCredential" />
<xs:enumeration value="deniedAuthenticationUnavailable" />
<xs:enumeration value="deniedAuthenticationFactorTimeout" />
<xs:enumeration value="deniedIncorrectAuthenticationFactor" />
<xs:enumeration value="deniedZoneNoAccessRights" />
<xs:enumeration value="deniedPointNoAccessRights" />
<xs:enumeration value="deniedNoAccessRights" />
<xs:enumeration value="deniedOutOfTimeRange" />
<xs:enumeration value="deniedThreatLevel" />
<xs:enumeration value="deniedPassback" />
<xs:enumeration value="deniedUnexpectedLocationUsage" />
<xs:enumeration value="deniedMaxAttempts" />
<xs:enumeration value="deniedLowerOccupancyLimit" />
<xs:enumeration value="deniedUpperOccupancyLimit" />
<xs:enumeration value="deniedAuthenticationFactorLost" />
<xs:enumeration value="deniedAuthenticationFactorStolen" />
<xs:enumeration value="deniedAuthenticationFactorDamaged" />
<xs:enumeration value="deniedAuthenticationFactorDestroyed" />
<xs:enumeration value="deniedAuthenticationFactorDisabled" />
<xs:enumeration value="deniedAuthenticationFactorError" />
<xs:enumeration value="deniedCredentialUnassigned" />
<xs:enumeration value="deniedCredentialNotProvisioned" />
<xs:enumeration value="deniedCredentialNotYetActive" />
<xs:enumeration value="deniedCredentialExpired" />
<xs:enumeration value="deniedCredentialManualDisable" />
<xs:enumeration value="deniedCredentialLockout" />
<xs:enumeration value="deniedCredentialMaxDays" />
<xs:enumeration value="deniedCredentialMaxUses" />
<xs:enumeration value="deniedCredentialInactivity" />
<xs:enumeration value="deniedCredentialDisabled" />
<xs:enumeration value="deniedNoAccompaniment" />
<xs:enumeration value="deniedIncorrectAccompaniment" />
<xs:enumeration value="deniedLockout" />
<xs:enumeration value="deniedVerificationFailed" />
<xs:enumeration value="deniedVerificationTimeout" />
<xs:enumeration value="deniedOther" />
</xs:restriction>
</xs:simpleType>
Example 1:
<BACnetAccessEvent>none</BACnetAccessEvent>
