accessPoint.accessAlarmEvents |
The value of this property is used as the value of the pAccessEvents parameter of the object's ACCESS_EVENT event algorithm for Access Alarm Events.
Property accessAlarmEvents of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.accessAlarmEvents |
<type> = 33 |
<property> = 245 |
A character string containing an XML with a value of type <SequenceOfBACnetAccessEvent>.
