accessPoint.accessTransactionEvents |
Used as the value of the pAccessEvents parameter of the object's ACCESS_EVENT event algorithm for Access Transaction Events.
Property accessTransactionEvents of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.accessTransactionEvents |
<type> = 33 |
<property> = 251 |
A character string containing an XML with a value of type <SequenceOfBACnetAccessEvent>.
