BACnetPropertyStates |
<xs:complexType name="BACnetPropertyStates">
<xs:sequence>
<xs:choice>
<xs:element name="BooleanValue" type="Boolean" />
<xs:element name="BinaryValue" type="BACnetBinaryPV" />
<xs:element name="EventType" type="BACnetEventType" />
<xs:element name="Polarity" type="BACnetPolarity" />
<xs:element name="ProgramChange" type="BACnetProgramRequest" />
<xs:element name="ProgramState" type="BACnetProgramState" />
<xs:element name="ReasonForHalt" type="BACnetProgramError" />
<xs:element name="Reliability" type="BACnetReliability" />
<xs:element name="State" type="BACnetEventState" />
<xs:element name="SystemStatus" type="BACnetDeviceStatus" />
<xs:element name="Units" type="BACnetEngineeringUnits" />
<xs:element name="UnsignedValue" type="Unsigned" />
<xs:element name="LifeSafetyMode" type="BACnetLifeSafetyMode" />
<xs:element name="LifeSafetyState" type="BACnetLifeSafetyState" />
<xs:element name="RestartReason" type="BACnetRestartReason" />
<xs:element name="DoorAlarmState" type="BACnetDoorAlarmState" />
<xs:element name="Action" type="BACnetAction" />
<xs:element name="DoorSecuredStatus" type="BACnetDoorSecuredStatus" />
<xs:element name="DoorStatus" type="BACnetDoorStatus" />
<xs:element name="DoorValue" type="BACnetDoorValue" />
<xs:element name="FileAccessMethod" type="BACnetFileAccessMethod" />
<xs:element name="LockStatus" type="BACnetLockStatus" />
<xs:element name="LifeSafetyOperation" type="BACnetLifeSafetyOperation" />
<xs:element name="Maintenance" type="BACnetMaintenance" />
<xs:element name="NodeType" type="BACnetNodeType" />
<xs:element name="NotifyType" type="BACnetNotifyType" />
<xs:element name="SecurityLevel" type="BACnetSecurityLevel" />
<xs:element name="ShedState" type="BACnetShedState" />
<xs:element name="SilencedState" type="BACnetSilencedState" />
<xs:element name="AccessEvent" type="BACnetAccessEvent" />
<xs:element name="ZoneOccupancyState" type="BACnetAccessZoneOccupancyState" />
<xs:element name="AccessCredentialDisableReason" type="BACnetAccessCredentialDisableReason" />
<xs:element name="AccessCredentialDisable" type="BACnetAccessCredentialDisable" />
<xs:element name="AuthenticationStatus" type="BACnetAuthenticationStatus" />
<xs:element name="BackupState" type="BACnetBackupState" />
<xs:element name="WriteStatus" type="BACnetWriteStatus" />
<xs:element name="LightingInProgress" type="BACnetLightingInProgress" />
<xs:element name="LightingOperation" type="BACnetLightingOperation" />
<xs:element name="LightingTransition" type="BACnetLightingTransition" />
<xs:element name="IntegerValue" type="INTEGER" />
<xs:element name="BinaryLightingValue" type="BACnetBinaryLightingPV" />
<xs:element name="TimerState" type="BACnetTimerState" />
<xs:element name="TimerTransition" type="BACnetTimerTransition" />
<xs:element name="BacnetIpMode" type="BACnetIPMode" />
<xs:element name="NetworkPortCommand" type="BACnetNetworkPortCommand" />
<xs:element name="NetworkType" type="BACnetNetworkType" />
<xs:element name="NetworkNumberQuality" type="BACnetNetworkNumberQuality" />
<xs:element name="EscalatorOperationDirection" type="BACnetEscalatorOperationDirection" />
<xs:element name="EscalatorFault" type="BACnetEscalatorFault" />
<xs:element name="EscalatorMode" type="BACnetEscalatorMode" />
<xs:element name="LiftCarDirection" type="BACnetLiftCarDirection" />
<xs:element name="LiftCarDoorCommand" type="BACnetLiftCarDoorCommand" />
<xs:element name="LiftCarDriveStatus" type="BACnetLiftCarDriveStatus" />
<xs:element name="LiftCarMode" type="BACnetLiftCarMode" />
<xs:element name="LiftGroupMode" type="BACnetLiftGroupMode" />
<xs:element name="LiftFault" type="BACnetLiftFault" />
<xs:element name="ProtocolLevel" type="BACnetProtocolLevel" />
<xs:element name="ExtendedValue" type="Unsigned32" />
</xs:choice>
</xs:sequence>
</xs:complexType>
Example 1:
<BACnetPropertyStates>
<BooleanValue>true</BooleanValue>
</BACnetPropertyStates>
Example 2:
<BinaryValue>inactive</BinaryValue>
Example 3:
<EventType>changeOfState</EventType>
Example 4:
<Polarity>normal</Polarity>
Example 5:
<ProgramChange>halt</ProgramChange>
Example 6:
<ProgramState>halted</ProgramState>
Example 7:
<ReasonForHalt>normal</ReasonForHalt>
Example 8:
<Reliability>noOutput</Reliability>
Example 9:
<State>fault</State>
Example 10:
<SystemStatus>downloadRequired</SystemStatus>
Example 11:
<Units>kilovoltAmperes</Units>
Example 12:
<UnsignedValue>1244</UnsignedValue>
Example 13:
<LifeSafetyMode>enabled</LifeSafetyMode>
Example 14:
<LifeSafetyState>testFaultAlarm</LifeSafetyState>
Example 15:
<RestartReason>detectedPoweredOff</RestartReason>
Example 16:
<DoorAlarmState>doorFault</DoorAlarmState>
Example 17:
<Action>reverse</Action>
Example 18:
<DoorSecuredStatus>unsecured</DoorSecuredStatus>
Example 19:
<DoorStatus>opening</DoorStatus>
Example 20:
<DoorValue>pulseUnlock</DoorValue>
Example 21:
<FileAccessMethod>streamAccess</FileAccessMethod>
Example 22:
<LockStatus>locked</LockStatus>
Example 23:
<LifeSafetyOperation>silence</LifeSafetyOperation>
Example 24:
<Maintenance>needServiceOperational</Maintenance>
Example 25:
<NodeType>system</NodeType>
Example 26:
<NotifyType>alarm</NotifyType>
Example 27:
<SecurityLevel>plain</SecurityLevel>
Example 28:
<ShedState>shedCompliant</ShedState>
Example 29:
<SilencedState>allSilenced</SilencedState>
Example 30:
<AccessEvent>deniedUnexpectedLocationUsage</AccessEvent>
Example 31:
<ZoneOccupancyState>belowLowerLimit</ZoneOccupancyState>
Example 32:
<AccessCredentialDisableReason>disabled</AccessCredentialDisableReason>
Example 33:
<AccessCredentialDisable>disableLockout</AccessCredentialDisable>
Example 34:
<AuthenticationStatus>waitingForAccompaniment</AuthenticationStatus>
Example 35:
<BackupState>backupFailure</BackupState>
Example 36:
<WriteStatus>successful</WriteStatus>
Example 37:
<LightingInProgress>idle</LightingInProgress>
Example 38:
<LightingOperation>stepUp</LightingOperation>
Example 39:
<LightingTransition>fade</LightingTransition>
Example 40:
<IntegerValue>-762</IntegerValue>
Example 41:
<BinaryLightingValue>warnOff</BinaryLightingValue>
Example 42:
<TimerState>running</TimerState>
Example 43:
<TimerTransition>idleToRunning</TimerTransition>
Example 44:
<BacnetIpMode>normal</BacnetIpMode>
Example 45:
<NetworkPortCommand>restartSlaveDiscovery</NetworkPortCommand>
Example 46:
<NetworkType>lontalk</NetworkType>
Example 47:
<NetworkNumberQuality>learned</NetworkNumberQuality>
Example 48:
<EscalatorOperationDirection>downRatedSpeed</EscalatorOperationDirection>
Example 49:
<EscalatorFault>mechanicalComponentFault</EscalatorFault>
Example 50:
<EscalatorMode>unknown</EscalatorMode>
Example 51:
<LiftCarDirection>none</LiftCarDirection>
Example 52:
<LiftCarDoorCommand>close</LiftCarDoorCommand>
Example 53:
<LiftCarDriveStatus>stationary</LiftCarDriveStatus>
Example 54:
<LiftCarMode>earthquakeOperation</LiftCarMode>
Example 55:
<LiftGroupMode>fourWay</LiftGroupMode>
Example 56:
<LiftFault>liftShaftDeviceFault</LiftFault>
Example 57:
<ProtocolLevel>nonBacnetApplication</ProtocolLevel>
Example 58:
<ExtendedValue>2401</ExtendedValue>
