BACnetNetworkType |
<xs:simpleType name="BACnetNetworkType">
<xs:enumeration value="ethernet" />
<xs:enumeration value="arcnet" />
<xs:enumeration value="mstp" />
<xs:enumeration value="ptp" />
<xs:enumeration value="lontalk" />
<xs:enumeration value="ipv4" />
<xs:enumeration value="zigbee" />
<xs:enumeration value="virtual" />
<xs:enumeration value="ipv6" />
<xs:enumeration value="serial" />
</xs:restriction>
</xs:simpleType>
Example 1:
<BACnetNetworkType>ethernet</BACnetNetworkType>
