BACnetLifeSafetyMode |
<xs:simpleType name="BACnetLifeSafetyMode">
<xs:enumeration value="off" />
<xs:enumeration value="on" />
<xs:enumeration value="test" />
<xs:enumeration value="manned" />
<xs:enumeration value="unmanned" />
<xs:enumeration value="armed" />
<xs:enumeration value="disarmed" />
<xs:enumeration value="prearmed" />
<xs:enumeration value="slow" />
<xs:enumeration value="fast" />
<xs:enumeration value="disconnected" />
<xs:enumeration value="enabled" />
<xs:enumeration value="disabled" />
<xs:enumeration value="automaticReleaseDisabled" />
<xs:enumeration value="default" />
</xs:restriction>
</xs:simpleType>
Example 1:
<BACnetLifeSafetyMode>off</BACnetLifeSafetyMode>
