BACnetNetworkPortCommand |
<xs:simpleType name="BACnetNetworkPortCommand">
<xs:enumeration value="idle" />
<xs:enumeration value="discardChanges" />
<xs:enumeration value="renewFdRegistration" />
<xs:enumeration value="restartSlaveDiscovery" />
<xs:enumeration value="renewDhcp" />
<xs:enumeration value="restartAutonegotiation" />
<xs:enumeration value="disconnect" />
<xs:enumeration value="restartPort" />
</xs:restriction>
</xs:simpleType>
Example 1:
<BACnetNetworkPortCommand>idle</BACnetNetworkPortCommand>
