loadControl Object
loadControl Object
Defines a standardized object whose properties represent the externally visible characteristics of a mechanism for controlling load requirements. A BACnet device can use a Load Control object to allow external control over the shedding of a load that it controls. The mechanisms by which the loads are shed are not visible to the BACnet client. One or more objects may be used in the device to allow independent control over different sub-loads. The Load Control object may also be used in a hierarchical fashion to control other Load Control objects in other BACnet devices.
Objects of type loadControl have the following properties:
•ackedTransitions
•actualShedLevel
•description
•dutyWindow
•enable
•eventAlgorithmInhibit
•eventAlgorithmInhibitRef
•eventDetectionEnable
•eventEnable
•eventMessageTexts
•eventMessageTextsConfig
•eventState
•eventTimeStamps
•expectedShedLevel
•fullDutyBaseline
•notificationClass
•notifyType
•objectIdentifier
•objectName
•objectType
•presentValue
•profileLocation
•profileName
•propertyList
•reliability
•reliabilityEvaluationInhibit
•requestedShedLevel
•shedDuration
•shedLevelDescriptions
•shedLevels
•startTime
•stateDescription
•statusFlags
•tags
•timeDelay
•timeDelayNormal
•valueSource
