loadControl.fullDutyBaseline |
Indicates the baseline power consumption value for the sheddable load controlled by this object, if a fixed baseline is used. Shed requests may be made with respect to this baseline, that is, to "percent of baseline" and "amount off baseline". The units of Full_Duty_Baseline are kilowatts.
Property fullDutyBaseline of object loadControl can be read and written using a single IOTag.
loadControl-<objectAddress>.fullDutyBaseline |
<type> = 28 |
<property> = 215 |
A 32-bit floating point number.
