loadControl.actualShedLevel
Indicates the actual amount of power being shed in response to a load shed request. When the object is in the SHED_INACTIVE state, this value shall be equal to the default value of Requested_Shed_Level. After Start_Time plus Duty_Window has elapsed, this value shall be the actual shed amount as calculated based on the average value over the previous duty window. The units for Actual_Shed_Level are the same as the units for Requested_Shed_Level.
Property actualShedLevel of object loadControl can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
loadControl-<objectAddress>.actualShedLevel
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 28
N3:
<objectAddress>
N4:
<property> = 212
Tag Value
•A 32-bit unsigned integer.
•A character string containing an XML with a value of type <Unsigned>.
•A 32-bit floating point number.
