loadControl.shedDuration |
Indicates the duration of the load shed action, starting at Start_Time. The units for Shed_Duration are minutes. If no shed request is pending or active, Shed_Duration shall be zero. If a load control command has been issued, and execution of the command has completed, Shed_Duration shall be reset by the device to zero.
Property shedDuration of object loadControl can be read and written using a single IOTag.
loadControl-<objectAddress>.shedDuration |
<type> = 28 |
<property> = 219 |
A 32-bit unsigned integer.
