loadControl.expectedShedLevel
Indicates the amount of power that the object expects to be able to shed in response to a load shed request. When the object is in the SHED_INACTIVE state, this value shall be equal to the default value of Requested_Shed_Level. When a shed request is pending or active, Expected_Shed_Level shall be equal to the shed level the object expects to be able to achieve at Start_Time. Expected_Shed_Level allows a client (e.g., a master-level Load Control object) to determine if a pending shed request needs to be modified in order to achieve the requested shed level, in the event that Expected_Shed_Level is less than the Requested_Shed_Level. The units for Expected_Shed_Level are the same as the units for Requested_Shed_Level.
Property expectedShedLevel of object loadControl can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
loadControl-<objectAddress>.expectedShedLevel
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 28
N3:
<objectAddress>
N4:
<property> = 214
Tag Value
•A 32-bit unsigned integer.
•A character string containing an XML with a value of type <Unsigned>.
•A 32-bit floating point number.
