BACnetNotificationParameters_ChangeOfDiscreteValue_NewValue |
<xs:complexType name="BACnetNotificationParameters_ChangeOfDiscreteValue_NewValue">
<xs:sequence>
<xs:choice>
<xs:element name="Boolean" type="Boolean" />
<xs:element name="Unsigned" type="Unsigned" />
<xs:element name="Integer" type="INTEGER" />
<xs:element name="Enumerated" type="Enumerated" />
<xs:element name="Characterstring" type="CharacterString" />
<xs:element name="Octetstring" type="OctetString" />
<xs:element name="Date" type="Date" />
<xs:element name="Time" type="Time" />
<xs:element name="Objectidentifier" type="BACnetObjectIdentifier" />
<xs:element name="Datetime" type="BACnetDateTime" />
</xs:choice>
</xs:sequence>
</xs:complexType>
Example 1:
<BACnetNotificationParameters_ChangeOfDiscreteValue_NewValue>
<Boolean>true</Boolean>
</BACnetNotificationParameters_ChangeOfDiscreteValue_NewValue>
Example 2:
<Unsigned>1234</Unsigned>
Example 3:
<Integer>-799</Integer>
Example 4:
<Enumerated>2</Enumerated>
Example 5:
<Characterstring>Abcde</Characterstring>
Example 6:
<Octetstring>FF</Octetstring>
Example 7:
<Date>2020-12-20</Date>
Example 8:
<Time>22:39:15.980</Time>
Example 9:
<Objectidentifier>device-506</Objectidentifier>
Example 10:
<Datetime>
<Date>2023-12-20</Date>
</Datetime>
