BACnetEventParameter_Extended_Unnamed |
<xs:complexType name="BACnetEventParameter_Extended_Unnamed">
<xs:sequence>
<xs:choice>
<xs:element name="Null" type="Null" />
<xs:element name="Real" type="REAL" />
<xs:element name="Unsigned" type="Unsigned" />
<xs:element name="Boolean" type="Boolean" />
<xs:element name="Integer" type="INTEGER" />
<xs:element name="Double" type="Double" />
<xs:element name="Octetstring" type="OctetString" />
<xs:element name="Characterstring" type="CharacterString" />
<xs:element name="Bitstring" type="BitString" />
<xs:element name="Enumerated" type="Enumerated" />
<xs:element name="Date" type="Date" />
<xs:element name="Time" type="Time" />
<xs:element name="Objectidentifier" type="BACnetObjectIdentifier" />
<xs:element name="Reference" type="BACnetDeviceObjectPropertyReference" />
</xs:choice>
</xs:sequence>
</xs:complexType>
Example 1:
<BACnetEventParameter_Extended_Unnamed>
<Null />
</BACnetEventParameter_Extended_Unnamed>
Example 2:
<Real>1234.567749</Real>
Example 3:
<Unsigned>1235</Unsigned>
Example 4:
<Boolean>true</Boolean>
Example 5:
<Integer>-798</Integer>
Example 6:
<Double>123459.789012</Double>
Example 7:
<Octetstring>FF</Octetstring>
Example 8:
<Characterstring>Abcde</Characterstring>
Example 9:
<Bitstring>1</Bitstring>
Example 10:
<Enumerated>4</Enumerated>
Example 11:
<Date>2022-12-20</Date>
Example 12:
<Time>22:39:15.980</Time>
Example 13:
<Objectidentifier>device-508</Objectidentifier>
Example 14:
<Reference>
<ObjectIdentifier>device-509</ObjectIdentifier>
<PropertyIdentifier>allWritesSuccessful</PropertyIdentifier>
<PropertyArrayIndex>1244</PropertyArrayIndex>
<DeviceIdentifier>device-512</DeviceIdentifier>
</Reference>
