SequenceOfUnsigned
SequenceOfUnsigned
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•channel.executionDelay
•credentialDataInput.supportedFormatClasses
•loadControl.shedLevels
•multiStateInput.alarmValues
•multiStateInput.faultValues
•multiStateValue.alarmValues
•multiStateValue.faultValues
Esquema XML
  <xs:complexType name="SequenceOfUnsigned">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="Unsigned" type="Unsigned" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfUnsigned" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfUnsigned />
</Value>
Exemplo 2:
  <SequenceOfUnsigned>
    <Unsigned>1234</Unsigned>
    <Unsigned>1235</Unsigned>
    <Unsigned>1236</Unsigned>
  </SequenceOfUnsigned>
</Value>
